1990 Eagle Talon TSi AWD Vehicle Profile & Build Thread
wishful_laser's Talon TSi AWD
Eagle Talon TSi AWD
:custom JMF smim with adjustable heat reducing silicon couplers:Q45 throttle body:1000cc FIC injectors:walbro 255hp:FP T67 T4 turbo:DNP T4 stainless tubular manifold:tial 38mm wastegate:custom 3in O2 housing with vband:3in downpipe to 3in flex:4in exhaust from flex back with a stainless steel Dynomax 4in muffler: SBR racing fmic with stainless steel piping.......very very big intercooler:tial 50mm bov GM MAF translator with a 3.5in gm maf:SBR cop ignition:94 cam angle "hall effect" sensor with higher resolution:custom 4in intake snorkel with a 4in K&N air filter: new alternator and belt:solid front motor mount:fluidyne aluminum radiator: aftermarket electric slim line fans:coolingmist meth/water injection kit with dual sprayer:
Mods-Engine
2.3L stroker motor: manley rods:wisco 8.8:1 pistons:all arp bolts:balance shafts eliminated:felpro 4 layer metal head gasket with arp head studs:port and polished head with 1mm over sized nitrate coated stainless steel valves:bronze valve guides:dual si springs with manley titanium retainers: FP 3 cams:fidanza adjustable cam gears: greddy kevlar timing belt:new front case and oil pump
Mods-EMS & Logging
DSMLINK:blitz electronic boost controller with 4 on the fly settings:blitz turbo timer:summit racing digital coolant temp gauge: AEM wide band with digital gauge:autometer oil pressure gauge:autometer boost gauge:
Mods-Drivetrain
Spec stage 5 clutch with a 6 puck unsprung disc:Fidanza lightweight aluminum flywheel:steel braided clutch line:welded center diff:4 bolt rear end:upgraded shifter bushing mounts:upgraded shifter cable bushings:
cross-drilled and slotted front and rear rotors with ceramic pads:synthetic brake fluid:matrix adjustable coilovers:kyb agx adjustable struts in front and rear 4 way in the front and 8 way in the rear:REV model 6 lightweight rims with 225/45/17 with Nankang Sport RS-1 rubber
Parts Wishlist
upgraded axles:shep tranny:two piece driveshaft:new exhaust mani(already ordered should be here friday):beefier t-case:(
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Track Name : Kennedale Texas
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3550
Tires : Street Radials
Sponsored Car : no
372.8 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
Speedtek Performance
Dyno Session Details
Nitrous : No Nitrous
Turbo : GT35R
Boost : 21
1G DSM
wishful_laser
More in 1G DSM
Share this vehicle
