1991 Eagle Talon TSi AWD Vehicle Profile & Build Thread
whitedawg's Talon TSi AWD
Eagle Talon TSi AWD
Precision Dual Ball Bearing T67 turbo T4, .68 A/R, S-Compressor Cover (4 in, 2.5 out)
Dark Performance Exhaust Manifold, T4 flange, 44mm wastegate flange
Tial 44mm Wastegate
Custom 3 inch TurboBack Exhaust w/Apexi N1 Muffler
Straightline Specialties Race Core Front Mount 28 x 10.5 x 3.62
Custom Polished 3 inch intercooler pipes
JM Fabrications Intake Manifold
Q45 90 mm Throttle Body
ShepRacing Stage 3 transmission w/welded center diff
Fidanza Short Shifter
4 Bolt Rear End
FIC Fuel Rail, -8 inlet, -6 return
FIC 1000cc Injectors
Dual Walbro 255 pumps,-10 feed, SX Regulator, Aeromotive Filter
ACT 2900 Maxx Xtreme Clutch w/South Bend Disk
ACT EXACT Streetlite Flywheel
Mods-Engine
4G63 2.3 Liter 6 Bolt Block
85.5mm Bore X 100mm Stroke (2.4 Crank), Balance Shafts Removed
Scat Rods, Wiseco Stroker Pistons 8.8:1 .020 over
Clevite Main & Rod Bearings
ARP Head, Main, and Rod Studs
Manley Valves, Manley Springs, Manley Titanium Retainers
Stage 5 Race Head, Port Work & Valve Job
3rd Generation Lifters (Larger Bore)
Fel-Pro PermaTorque MLS Head Gasket
Kelford 272 Intake/Exhaust Cams
15x7" ATS Superlite Comp Wheels
225/50/15 BFG G-Force T/A Drag Radials
Hyperco Hypercoils Lowering Springs
Auto Zone Shocks
Manual Steering Rack
VIS Carbon Fiber Hood
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
1G DSM
whitedawg
More in 1G DSM
Share this vehicle
