- Ownership Status
- Currently Own
- Year
- 1996
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 50-trim
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- K&N cone air filter || 1G BOV || 2G Magnus Street Intake Manifold || 1G Throttle Body || Megan 3" Turbo Back Exhaust || Tubular O2 Housing || FP Exhaust Manifold || FIC Hi-Z 2150cc Injectors || Walbro 255 HP || 034 Motorsports Surge Tank w/ Bosch 044 Pump || Aeromotive AFPR || -8 fuel Supply & Return Lines || Re-wired Fuel Pump || FP “Old School” Green || Dejon Tool Intake Pipe || Dejon Tool FMIC || Fluidyne Aluminum Radiator || Derale Power Steering Fluid Cooler || B&M Oil Cooler & Remote Filter || Moroso Oil Pan || Canton Racing Mega Buck$ Oil Filter || 12" Slimline Fan || EVANS NPGR Coolant || Mishimoto 143 deg Thermostat || RRE Crank Case Breather/Catch Can || NGK BR7EIX Spark Plugs || NGK Spark Plug Wires || Polyurethane Shifter Bushings ||BlackGST Poly Roll Stops || VIS Invader Hood || MOMO Rookie Seat...
- Mods-Engine
- 2G Head/6-bolt 4G64: English Racing Stage OMFG Port & Polish || 1mm Oversized Valves || Ferrea Seals & Guides || GSC S2 Camshafts || GSC Beehive Springs || ITM Revised Lifters || Fidanza Cam Gears - Retarded 3 Degree’s Intake & Exhaust || MAP H11 Head Studs ||Fel-Pro PermaTorque Gasket || Kiggly Racing HLA Pressure Regulator || Wiseco 10.5:1 1400HD Pistons || Crower Billet I-Beam Rods || ARP Main Studs || Kiggly Racing 6-Bolt Main Girdle || ACL Bearings || ATI Harmonic Damper || Balance Shafts Eliminated...
- Mods-EMS & Logging
- DSMLink : SD + Boost Control || Auto Meter Boost, Fuel Pressure, Oil Temp, Transmission Temp & Coolant Temp gauges || Innovate LC-1 Wideband...
- Mods-Drivetrain
- Spec Stage 3+ clutch || Fidanza Aluminum Flywheel || ARP Flywheel Bolts || SS Clutch line || Red Line Fluids || Manual Transmission cooling system w/ B&M cooler, Tilton pump ect...
- Mods-Handling
- 5zigen FNO1R-C 17X9 35mm Offset Wheels || 255/40-17 Nitto NT-O1's || RM Racing Front Anti-Sway Bar & OEM Rear Anit-Sway Bar || RRE Front Strut Tower Brace || POS Rear Strut Tower Brace || AEM Front & Rear Oversized Brake Rotors || Porterfield R4-E (front) Porterfield R4 (rear) Pads || SS Brake Lines || RRE Pillowballs || GC Coilovers & coaxial hats || Koni Sports || Eibach (600/300) springs || SPC Control Front Arms || 3G Rear Upper Control Arms || -3.0 Degrees Front & -1.6 Degrees Rear Camber || Prothane Bushing's || BlackGST Aluminum Subframe Bushings Front & Rear ||Tanabe Underbrace...
- Parts Wishlist
- An enclosed trailer
