- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- full prothane bushing kit, custom A/C system, complete crown vic: wiring/fuse, fuel and EMS system swapped in. crown vic fuel tank used as primary tank, stock tank as slip tank with transfer pump, 36 gallon capacity, flexfuel compatible.
- Mods-Engine
- Ford 4.6 2v engine from 2010 Crown Vic police interceptor, custom intake, headers and exhaust, remote oil filter and lower radiator hose plate. all aluminum 3 core radiator, pcm controlled electric fan.
- Mods-EMS & Logging
- Stock PCM, Mo's Speed Shop M/T tune with SCT tuner, Speed Hut and Innovate gauges in custom gauge cluster.
- Mods-Drivetrain
- built R150F transmission, billet bearing plate, chromoly thrust washer, R452 5th gear swap, Spec Stage 2 clutch kit, fidanza chromoly flywheel, custom pilot bearing.
- Mods-Handling
- Sway-A-Way torsion bars, ARB 2" lift rear leaf springs, bilstein shocks
