- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT30 Variant
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Homemade intake.
Hotwired Supra FP.
FIC 1150's
Aeromotive FPR
MSD 8.5 mm wires.
FP Race exhaust manifold.
FP Red HTA
Punishment FMIC
Dual R35GTR BOV's.
38mm Tial WG
Modded RNR internal dump turboback with 3 Dynomax bullet's.
Fluidyne radiator w/surge tank.
so far.
- Mods-Engine
- Fresh mildly ported 2g head.
RVR/EVOIII intake manifold.
Phenolic intake spacer.
Fidanza cam gears.
GSC S1 cams.
BC valvesprings/Ti retainers.
Cometic MLS headgasket.
ARP head studs.
ARP rod bolts/resized rods.
Balance shafts eliminated.
Fluidamper.
OBX oil pan.
Kiggly HLA
3g lifters
- Mods-EMS & Logging
- Autometer 35# boost gauge.
Turbo timer.
ECMLink w/speed density, flex-fuel and ECU boost control.
- Mods-Drivetrain
- Fidanza flywheel.
Horsepowerfreaks 6-puck/ACT 2100 clutch combo.
TMZ trans. w/GVR4 first gear.
Prothane engine mounts.
PTFE shift bushings, solid shifter mounts, BMX grinder-peg shift grip.
- Mods-Handling
- 12kg/10kg on Ksport RR coilovers.
Dejon f. bumper support.
ABS splitter.
Hood vented.
PC680 mounted behind pass. seat.
Under-car power steering coolers.
Reinforced Polk f. control arms with delrin bushings and Howe lengthened front ball joints.
Heim joint/bump steer corrected tie rod ends.
Adj. upper radius arms.
Boxed lower radius arms w/urethane inner bushings.
UHMW rear subframe bushings.
Active-Toe Eliminated.
Whiteline 26mm rear swaybar.
245-40x17 Bridgestone RE-01R's.
17x9 TDR wheels.
Front brake ducts.
TCE 13x1.25 w/6 piston Wilwoods.
Cockpit adjustable proportioning valve.
- Parts Wishlist
- Roll cage.
Race seats.
Harnesses.
Racing steering wheel w/QR.
Digital dash.
R compound tires or slicks.
Forged guts short block w/9:1 CR.
2-pass radiator w/internal oil cooler.
2 piece driveshaft,
Full undertray.
Carbon-fibre hood
- Background
- Bought in '05 as a fun winter car. Became a project instead.
Road course toy, summer daily beater.
- Timeslip Details
- Vehicle Weight : 3160
- Dyno HP
- 326.7 whp
- Dyno TQ
- 273.9 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Beyond Redline, Green Bay WI
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : E-zero 91 octane Pump gas
24 psi max boost
7 runs to establish a good tune, 2 more to fine tune.
Last 2 runs were 321, 326.
These stats are with the old 50-trim.
