1995 Eagle Talon TSi AWD Vehicle Profile & Build Thread
Turbo Smurf's Talon TSi AWD
Eagle Talon TSi AWD
Custom CAI and intercooler ducting in 2.5" mandrel-bent aluminum, FMIC, ball-bearing turbo, TiAL BOV, 3" GM MAF with MAFT, 1g throttle, Magnus SMIM. 720cc Denso injectors, 1g fuel rail, -6AN fuel feed/return lines (tank to rail), Supra TT fuel pump, big fuel filter and adj. FPR. Ported 2g exhaust manifold, HRC 3" o2 elim housing with full 3" downpipe, test pipe, and Thermal exhaust. Alum flywheel with CM stage 3 kevlar clutch. DSM Chips EEProm, E-01 and e-Manage. TE wideband o2 and Team RIP EGT.
Mods-Engine
Comp Cams - stage 2 intake and exhaust, big hole lifters.
Stock 2 piston front calipers and factory vented rear discs, Tokico Illumina spring/shock kit, Home Depot rear camber kit, Prothane suspension bushings, RMDSM front and rear anti-sway bars, 17x7" 40mm offset wheels, 225/45/R17 tires, rubber mallet/baseball bat rear fender lip roll.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
0.0 lb/ft
2G DSM
Turbo Smurf
More in 2G DSM
Share this vehicle
