- Year
- 1998
- Model/Trim
- Eagle Talon TSi
- Transmission Type
- Automatic
- Mods-Bolt-on
- HKS turbo timer ,TURBO XS mbc ,DEJON TOOL intake pipe 85% over stock SBR FMIC WITH 2.5IN stainless steel pipes 24X12X3.5,ported o2 with ,HKS carbon ti exst,HKS ssqv,ported SBR B28 turbo with 34MM flapper,APEXi intake,MAGNECOR 8.5 mm wires,NGK BPR 7ES plugs,custom dp,APEXi SAFC,WALABORO 190LPH FUEL PUMP with rewire,LUCAS 550CC disc style inj.
- Mods-Engine
- ROSS 8:5:1 FORGED ALUMINUM PISTONS .20 BORE,EAGLE H BEAM RODS,ARP ROD BOLTS AND HEAD STUDS,CLEVITE ROD AND MAIN BEARINGS,REBIULT HEAD WITH 3 ANGLE VALVE JOB,AND BALANCED SHAFTS REMOVED PISTONS RODS AND CRANK WERE BALANCED, BLOCK AND CRADLE WAS LINE B
- Mods-Handling
- KYB AGX rear struts,KYB GR2 front struts, EIBACH pro kit springs,TOUCAN front and rear upper strut bars, 17in ADR SOKUDO'S gunmetal with polished lip 225/45/zr17 KUMHO ECSTA 711 tires,PROTHANE motor mounts, STILLEN slotted front rotors,STILLEN metallic racing brake pads front and rear and GOODRICHE stainless steel brake line front and rear
- Parts Wishlist
- FULLY BUILT TRANS
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Track Name : ATCO RACEWAY
Nitrous : no
Fuel Used : Pump gas
Vehicle Weight : 3150
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
