1990 Plymouth Laser RS Turbo Vehicle Profile & Build Thread
terefic181's Laser RS Turbo
Ownership Status
Currently Own
Turbo Type
16g
Drivetrain
FWD
Build Type
  1. Road Course
Fuel -6 braided line in & out w AN rail adapter kit, Paxton FPR w gauge, Walbro 255 fuel pump. 660's
Coldbox, K&N 3" in., 2G MAF, Fabbed 2.5"; UIC, MBC
Exhaust- Evo exhaust manifold, External dump, Megan 3"down and 3" out.
Upgraded oil and p/s cooler w ducting.
Aluminum p/s reservoir & oil & coolant catch cans.
Art's 3"; radiator. Hood exit scoop.
Roll cage w Kirkey aluminum seat.
Gauges: EGT, boost, oil p, h2o t, V.
Electronics: TMO chip reburned for 2G mas and 660 Injectors, SAFC, Pocketlogger, Fire system
Mods-Engine
Internals stock except for gasket ported, and ports polished head. Balance shafts removed, Adjustable cam gears, Energy Suspension motor mounts. Fidanza 8# flywheel with HP clutch & pp, Braided clutch line. 16G, 1 3/4" compressor outlet.
Mods-EMS & Logging
Gauges: EGT, boost, oil p, h2o tem, Volt.
Mods-Drivetrain
Fidanza 8# Alum flywheel with HP 6 puck clutch plate, Braided clutch line.
Coilovers, 450 lb front 350 lb rear, AGX's, HKS castor-camber plates front, Falken Azenis, brembo cross drilled rotors, all round. Hawk black pads front, Cool Carbon pads rear, RRE SS brake line, Suspension Techniques rear sway bar, tower stress bar front. Energy Suspension control arm bushings all round.
1/8 Mile E/T
0.000
1/8 Mile MPH
00.000
Timeslip Details
Vehicle Weight : <250
Tires : Street Radials
Dyno HP
000.0 whp
000.0 lb/ft
