- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- Custom 3" v-band o2/downpipe, Dejon 3" exhaust, rewired Walbro 255 high pressure, FIC 1680's, Fuelab AFPR, inline fuel filter, -6AN fuel sending/return lines, Kinetic Race FMIC, TiAL bov, blow-thru gm maf, 4" custom cold air intake, Cyclone intake manifold, Punishment divided T3 manifold, 7-blade HX35 w/ 12cm^2 housing, twin TiAL MV-S wg, solid front roll stop, Prothane motor mounts
- Mods-Engine
- 2.3L 6-bolt, Mahle 9.0:1 pistons on Manley H-beams, Eagle forged 100mm crank, ACL race bearings, Kiggly main girdle, turned down rear balance shaft, ARP rod bolts and main studs, H11/L19 head studs, OE MLS headgasket, GSC S2 274/274 cams, GSC beehive springs, titanium retainers, Evo IX lifters, Evo oil squirters, Fidanza adjustable cam gears, Fluidampr harmonic damper
- Mods-EMS & Logging
- DSMLink v2.5, AEM WB, AEM 3.5bar, MAF-T
- Mods-Drivetrain
- Southbend SS-X Pressure plate, TZ Kevlar clutch disk, ACT Streetlite Flywheel, 92 awd trans rebuilt w/ 4 spider center diff, evo3 input shaft, evo3 gearset, 4 bolt rear end swap
- Mods-Handling
- 235/45/17 Continental ExtremeContact DW on Evo8 Enkeis, 1g front Koni yellow shocks, 2g rear Koni yellow shocks, Ground Control coilover sleeves, Dual Piston Big Brakes, JayRacing passive toe eliminator, rear subframe/mustache bar poly bushings, adjustable rear upper control arms, Whiteline 26mm rear sway bar/poly bushings
- Parts Wishlist
- a good tune
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
