- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Galant VR-4
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Showcar
- Mods-Bolt-on
- HKS cam gears, HKS blow off valve, custom charge pipes, exhaust manifold with heat wrap, custom exhaust, custom carbon fiber air box, custom fuel system with trunk mounted fuel cell, all steel braided AN fitted lines, coil on plug setup mounted on carbon kevlar plate, front mount intercooler
- Mods-Engine
- EVO II Pistons, HKS cams
- Mods-EMS & Logging
- ECU flash, Autometer fuel level, fuel pressure, volts, water temp, oil temp, oil pressure gauges, Blitz boost gauge, Pivot turbo timer, Greddy boost controller
- Mods-Drivetrain
- Stage 2 clutch
- Mods-Handling
- Brembo front brakes, slotted rotors, Rally suspension, 17" Racing Hart CR wheels, carbon fiber front strut tower brace, rear strut tower brace, chassis bracing
- Parts Wishlist
- Bigger turbo and supporting mods, coilovers with air cups
- Background
- Built in Japan. I'm the first US owner. Super VR-4 was only made one year and only in Japan so it may be the only one currently in the states. Possibly the only widebody 6th gen Galant in the world.
