1. Join the Community!
Street Build Street build
Year:
1992
Model/Trim:
Eagle Talon TSi AWD
  • Ownership Status:
    I own it
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Street
    • Drag Race
    Mods-Bolt-on:
    Ported 2g manifold PTE 5252 DSM bolt on 3in 02 with external gate on 02 custom made 3in bumper exit wally 255 rewired AEM fuel rail FIC 1050 injectors Aeromotive afpr punishment fmic stock 1g bov wit dodge garage mod
    Mods-Engine:
    Stock 6 bolt short block built head with gsc valves and gsc valve seals kiggly springs and retainers hks 272 cams obx adj cam gears arp studs
    Mods-EMS & Logging:
    Link V3 full with SD plug and play kit innovate LC1
    Mods-Drivetrain:
    Stock drivetrain comp clutch 6 puck then all clutch hydraulics replaced with new OEM parts
    Mods-Handling:
    Abs delete evo 8 wheels rest stock
    Parts Wishlist:
    Morrison stock replacement manifold all paul volk stuff offered front and rear for 1g dsm feal coilovers 300m t case built trans DSS driveshaft and axles boostin performance shifter assembly ctsv brake swap and upgrade fuel system for e85
    Background:
    The talon had been passed threw a couple different friends and then was eventually parted out. I then bought it from my good friend nathan Stover who had put a good 6 bolt in and built the head before I purchased the vehicle. I then did maintenance then started buying my mods threw out 2019 and just recently got first start up!
Share this Item
Comments
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
