- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse Spyder GST
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- FP green uhf, FIC2150CC injectors, magnus fuel rail, fuelab fpr, 8an fuel lines to tank , walbro 255 fuel pump aem cam gears, 264/264cams brian crower valve springs, evo3 ofh, manley 9to1 forged pistons, manley hbeam rods, acl rod and main bearings, evo 8 crank, arp head and main studs,no name 3in frontmount, 3in intercooler piping, fluidampr crank pully boosted fabrication cross member, and more i cant think of
- Mods-Engine
- manley forged h beam rods, manley forged 9-1 pistons, balance shaft delete, oem 1.6L mitsubishi stub shaft in oil pump, oem evo3 ofh(oil feed to turbo), fluidampr harmonic dampr, ACL main and rod bearings, ARP standard head studs and main studs, cometic head gasket Tomei 4G63 Thermo Killer (deletes ofh thermostat and always runs oil through oil cooler), aftermarket oil cooler, brand new oem mitubishi oil pump, gates oe timing belt, mishimoto upper and lower radiator hoses
- Mods-EMS & Logging
- innovate lc2 ecm link v3
- Mods-Drivetrain
- converted auto to manual
trans out of 99 gst, OE left and right axles, Fidanza 7-Bolt FWD flywheel, ACT Clutch 2100 Kit w/ Sprung 6-Puck, braided stainless clutch line from master to slave, Boosted Fabrication Chromoly Crossmember /Roll Stop
- Mods-Handling
- BCRacing br adjustable coilovers with swift springs, volk adjustable front lower control arms w/ spherical bearings, oe front upper control arms, volk adjustable rear lower control arms, volk adjustable toe arms, volk tubular adjustable rear Trailing Arms, RM Racing Sway Bar front and rear, OEM GVR4 front knuckles,
