- Ownership Status:
- I own it
- Drivetrain:
- FWD
- Transmission Type:
- Manual
- Build Type:
- Street
- Drag Race
- Road Course
- Showcar
- Mods-Bolt-on:
- - Yonaka catback system.
- Fire extinguisher (just in case).
- 3 gauge cluster .
- Bosch gauges (vacuum/boost, oil pressure, voltage).
- Full evap deletion.
- Mods-Engine:
- - Cold air intake (inverted cone filter).
- 4-1 headers and down-pipe (heat wrapped).
- New rings.
- Decked heads and machined block. All mating surfaces are leveled to spec.
- VMS Racing plug wires, NGK spark plugs.
- K&N oil filter.
- Vacuum box delete.
- Custom bored and smoothed stock intake manifold.
- Some aftermarket radiator.
- Fel-Pro intake manifold and throttle body gaskets.
- Mods-Drivetrain:
- - Megan Racing short shifter.
- Full Exedy clutch system.
- Energy Suspension shifter bushings on interior.
- Torque Solution shifter bushings in the bay.
- Trans work from the PO
- Mods-Handling:
- - Eibach Ground Control coil overs
- Tokico struts (front)
- Gabriel struts (rear)
- Megan Racing strut bar (front).
- 16 inch KONIG Racing wheels.
- All new ball joints and control arms.
- Powerstop drilled and slotted rotors on the front.
- 3F power steering pump.
- Parts Wishlist:
- - I want a perfect paint job. (I did a dirty garage job)
- Megasquirt ecu.
- Underdrive pulley.
- Sparco seats and steering wheel.
- Drag race intake manifold.
- Jeep or larger throttle body.
- High performance timing belt and clear timing cover.
- MSD coil pack
- Wiseco 10.5:1 pistons.
- Eagle rods.
- MLS headgasket.
- ARP headstuds.
- Megan Racing strut bar for REAR.
I'm not looking to set records here, I just want a peppy 420a and a good looking car.
- Background:
- Currently a 190psi compression engine.
Just because it's a N/T doesn't mean it's cheap.
Wrecked (minor): 8/26/2019
Purchased: 1/4/2018. It was dumping oil out of the engine. I was lucky to make it home (no, I didn't have a trailer). The car was in nasty condition, its 1000% better now but I'm still working on it. I have been an influence on my friends and family with this car, they like DSM's now.
Join the Community!
Share this Item
CarNage, TNi, natty_boy86 and 1 other person like this.
Comments
Sort Comments By
