1998 Mitsubishi Eclipse N/T Vehicle Profile & Build Thread
Road Race Build
Too much time and too much money spent.
(Sold but not forgotten) Solomon's 2GNT Build ('98 RS)
Ownership Status
No Longer Own
Drivetrain
FWD
Build Type
  1. Street
  2. Drag Race
  3. Autocross
Exhaust:
- 4-1 SS header & down-pipe (heat wrapped).
- Megan Racing SS test pipe.
- Rear O2 delete and capped off.
- Yonaka Motorsports 2.5" SS cat-back system.
Fuel System:
- Walbro 255lph fuel pump.
- ProTune high flow fuel filter.
- Fuel Injector Clinic 350cc.
Body/Exterior/Interior:
- Archer Fabrications aluminum spare tire delete panel.
- Spoiler, rear wiper, & antenna delete. Smooth bodywork.
- Konig Incident Graphite 16x7 wheels.
Mods-Engine
Bottom End:
- '98 Neon block, 0.020" over bore & shaved.
- JE forged pistons (10.5:1 CR).
- ProSeal piston rings (1.2, 1.2, 3.0 grooved).
- Eagle H-beam rods and ARP bolts (5608.DNA).
- Mahle Clevite main & rod bearings (MS-2028A).
- Modern Performance MPX crankshaft underdrive pulley.
Cylinder Head:
- Crower Stage 2 camshafts (64462).
- SBI +1mm valves.
- Brian Crower titanium springs & retainers (BC2160).
- Fidanza adjustable cam gears.
- MLS headgasket (Fel-Pro PermaTorque).
- ARP headstuds (141-4202).
- Gates blue RPM timing belt (T246RB).
- Shaved head & mild port work.
- PT lifters.
- 2.7L angled rocker arms.
- Dodge 2.4L valve cover & custom breather.
Cooling System:
- 160 degree thermostat.
- Samco silicone radiator hoses.
- Replacement radiator.
Intake:
- 3" intake pipe to K&N pod filter.
- Modified Jeep 60mm throttle body.
- 59mm plenum port matched to throttle body.
Weight reductions / bay cleanup:
- EGR delete and block off plates.
- EVAP deleted completely.
- Cruise control delete.
- A/C & tensioner delete.
Mods-EMS & Logging
- MS3 standalone.
- GlowShift wideband 02 and 52mm digital gauge, in conjunction with MS socket to eliminate OE sensor.
Mods-Drivetrain
NV-T350 Transmission Build:
- Quaife LSD.
- TPD brass alloy synchronizers 100%.
- Drilled casing oil passages.
All Others:
- New Mopar shift cables.
- Megan Racing short shifter.
- Energy Suspension polyurethane shifter base bushings.
- Torque Solutions cable end bushings.
- SouthEast Stage 1 clutch kit.
- Polyurethane engine and transmission mounts.
- 2gnt lower engine mount bolt upgrade.
Suspension:
- Eibach Ground Control coil overs.
- Koni Yellow struts.
- Energy Suspension polyurethane bushings, front to back.
- Megan Racing rear toe bar.
Brakes:
- Front PowerStop D&S rotors.
- Brembo track pads.
- Rear disc brake conversion from drums.
Parts Wishlist
Still imagining...
Background
Purchased: 1/4/2018
Constantly turning wrenches to achieve my goals.
Dyno Type
Mustang Dyno
Dyno Shop Name
Dynomite Performance, Alabama
2G DSM
BLACK'98DSM
Watchers
9
Comments
15
More in 2G DSM
More from BLACK'98DSM
Share this vehicle
