1. Join the Community!
Sleeper Beauty
Year:
1998
Model/Trim:
Mitsubishi Eclipse GSX
  • Ownership Status:
    I own it
    Turbo Type:
    20g
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    GM MAF, FMIC, 3" SS Exhaust, Aluminum radiator
    Mods-EMS & Logging:
    Link V3, Innovate WB
    Mods-Drivetrain:
    Welded Center diff, ACT2600
    Background:
    It showed up with a built 2.3 bottom end, with no supporting mods. Eventually, I spun a bearing, and put in a stock 6 bolt top and bottom end. That build sh** the bed due to improper torque technique, a bent crank, over heating, and a ground issue in the harness for the MAF/TPS branch.
Share this Item
Comments
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com White Shed Speed
