SKOLJACK's Talon TSi AWD
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- K & N w/ custom cut air can, "FREE Mods", MBC set to 15 PSI, MOTOGUY'S ECU, PaceSetter Armor Coated Header, 2.5" Punishment downpipe, 2.5" test pipe, 3" RNR cat->back exhaust w/stainless Bullet muffler, Fluidyne radiator, HKS turbo timer, custom center vent triple gauge pod containing Boost, EGT, & Volt gauges, Fuel filter mounted B&M fuel pressure gauge, and a B&M shift knob.
- Mods-Engine
- Stock, Balance Shaft Delete Kit,
Total Seal Piston Rings, Cylinder Head Shaved .014", .020" Head Shim: (Compression is 150 PSI on all 4 cylinders)
- Mods-Handling
- 17" Drag DR-8 Wheels w/ Goodyear RS-A's (225/45HR17),
Front Strut Tower Brace,
Rear Strut Tower Brace,
KYB GR-2 Struts
- Parts Wishlist
- 2nd Gear Synchro-hub kit, 3" down pipe & 3" off-road pipe, tubular O2 housing, 550cc to 650cc fuel injectors, 255 lph fuel pump, UICP, FMIC, data logger, larger turbo, larger brakes.
