- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- Ebay Big16G, Header, Megan Racing downpipe, Megan Testpipe, Megan Cat back exhaust, Slowboy FMIC , Cold Air Intake, Koyo Racing Radiator and slim fans. Fluid damper.Custom turbotrix oil catch can setup with an lines.Stock ported o2 dump.
- Mods-Engine
- 2.3L Stroker Wiseco Pistons, Manley I Beam Rods, Mitsubishi Bearings, Racing Head. Brian Crower 280 Cams. Turbotrix stage 5 racing port job oversize 1mm valves with dual valve springs and etc.
- Mods-EMS & Logging
- AEM Standalone EMS, AEM wideband O2, autometer oil pressure, autometer 30/30 boost
- Mods-Drivetrain
- Quartermaster Twin disc with Map flywheel, modified new oem clutch fork, new oem pivot ball, new oem throwout bearing, ARP flywheel bolts, Brass Underhood Shifter Cable Bushings, Stainless Steel Clutch Line. 4 bolt rear end. Symborski Shifter Kit. Metal driveshaft carrier bearings. Turbotrix built trans for 750+whp all new gears evo 3&4 double synchros everything rem coated with new linkage.
- Mods-Handling
- Evo 9 BBS with Bridgstone Potenza, 2g dual piston calipers in the front with front and rear powerslot rotors and hawk hps pads. D2 RS coilovers. Megan Racing front and rear strut bars. Energy Suspension master bushing Kit. Maximal Performance adjustable rear upper control arms.
- Parts Wishlist
- DSS pro level axles in the rear and stage 5 axles in the front, DSS 3.5in heavy duty driveshaft,precision 6262 dual bb turbo kit,hard pipe intake, intake manifold, roll cage, racing seats, weight reduction, coil on plug setup, aem ignition controller, built transfercase for 750+whp
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 377.5 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- Turbotrix Racing
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Big 16G
Boost : 20
