1997 Mitsubishi Eclipse N/T Vehicle Profile & Build Thread
scorplon2004's Eclipse N/T (w/turbo)
Garrett GT3076R-WG Ball Bearing Turbo,
CI Manual Boost Controller,
Symtech Turbo Manifold,
Synchronic Blow Off Valve,
TSI High Flow Front-Mount Intercooler,
Custum 3" turbo back exhaust piping (no cat),
Race Muffler 3" inlet and outlet,
Electronics: Autometer Cobalt Gauges- Tachometer, Speedometer, EGT, Water Temp, Fuel Pressure, Fuel Level, Air Fuel Ratio
Mods-Engine
Cometic Head Gasket,
Wiseco Forged Pistons
(88mm 8.8-1),
Performance Rings,
Performance Wrist Pins,
TOGA HP Main Bearings,
TOGA HP Rod Bearings,
Eagle H Beam Rods.
Valve train:
Crower Stage 2 Camshafts,
Crower Spring w/titanium retainers,
PEP Stainless Steel Valves,
PT style Lifters and rocker arms,
AEM Cam Gears
Mods-EMS & Logging
034EFI 4 Injector setup for water meth:
460cc Injectors,
Primary Fuel System:
SS -6an Fuel Send and Return Line,
Aeromotive 1:1 FPR,
Walboro 255 lph HV,
750cc RC Injectors,
MS 3.0,
Innovate LC-1 Wideband
Mods-Drivetrain
Short Shifter
2003 Base Model Neon nvt-350 transmission, only year to get hydraulic clutch with 3.55 Final drive and .72 5th gear ratio.
Eibach Sportline Springs,
KYB GR2 Shocks/Struts,
19" Axis Sevens,
225/35/ZR19 Yokohama,
Parts Wishlist
2.7 Rocker Arms,
Custom Welded Intercooler Piping,
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
Videos
420a Turbo Start,Idle and Rev
420a Turbo, Garrett GT3076r turbo, 3" Turbo back no cat, Crower 2 Cams, Symtech turbo manifold, Race muffler (might as well be straight through, race muffler barely does anything!).
Table of contents
2G DSM
scorplon2004
Watchers
4
More in 2G DSM
Share this vehicle
