SaberKhanzz's Laser RS Turbo AWD
- Year
- 1992
- Model/Trim
- Plymouth Laser RS Turbo AWD
- Mods-Bolt-on
- 20G w/15 degree clip & ceramic coated turbine housing, ported 95' manifold, ported Evo3 o2 housing, BR 2.5 straight exhaust w/straight through Magnaflow muffler w/stock tips painted black, Spearco FMIC w/custom 2.5" IC pipe & HKS bov, 2G TB elbow, JDM ported Cyclone intake manifold, 3" GM MAS w/GM translator, rewired Walboro 304lph pump, Aeromotive/BR AFPR, RC 720cc injectors, S-AFC, 40mm Fluidyne aluminum racing radiator, VDO boost, Jumptronix 02/B+, Autometer EGT, Greddy timer, turbochargers.com boost controller
- Mods-Engine
- .020" 6 bolt, deleted B-shafts, removed oil squirters, polished crank, King Racing bearings, Mitsu MLS headgasket, stock rebuilt head, 94' tranny w/double 2nd gear synchro, ACT 2600 clutch, braided clutch line
- Mods-Handling
- RRE custom hybrid coil overs: Front- 400lb Eibach springs w/shortened Koni infinite adjustables, Rear- 275lb Eibach springs w/8way adjustable KYB's, RRE extreme front camber plates, ST rear swaybar, Energy Suspension bushings, 17" Rota Subzeros w/235/45/ZR-17 Potenza RE730's, stainless steel brake lines, EBC pads, Momo steering wheel, Pioneer Premier audio components
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
