1992 Plymouth Laser RS Turbo AWD Vehicle Profile & Build Thread
SaberKhan's Laser RS Turbo AWD
2.5" exh. w/cat 18psi on pump gas
Dynoed approx. 281awhp/280ft lbs
Estimated crank HP: 360-370hp
Big 16G w/FP enlarged WG, 95' pistons w/1G big rods, built 94' tranny w/4bolt LSD, ACT 2600 w/stainless clutch line, Fluidyne radiator, ported 95' manifold, ported Evo3 o2, 2.5" stainless exhaust w/RRE cat, 2G TB elbow, HKS bov, 2.5" IC piping w/Spearco FMIC, NGK plugs and wires, RC 550cc injectors, SX FPR, rewired Supra TT pump, S-AFC, datalogger w/palm pocketlogger, Boost/EGT gauges in vent.
RRE camber plates, Koni front inserts in RRE shortened struts
KYB AGX rear shocks, 400 Front / 275 Rear lb/in springs coil overs
Susp Techniques rear sway bar
93+ dual piston calipers w/ speed-bleeders, Carbotech Panther Plus pads front and rear w/stainless braided brake lines, Rota Subzero 17"x7.5" 16lb gunmetal, ContiSport 235/45R17's and a Momo steering wheel.
Parts Wishlist
RnR install kit for my T3/TO4E 60 trim ball-bearing turbo, 720cc injectors, turbo back 3 or 3.5" exhaust, Crane Ignition w/stutter box, Sparco seats/Roll cage and a sweet system ;)
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
1G DSM
SaberKhan
More in 1G DSM
Share this vehicle
