- Year
- 1990
- Model/Trim
- Plymouth Laser RS Turbo
- Transmission Type
- Manual
- Mods-Bolt-on
- 2G Ported Manifold, 2g Ported O2 Housing w/External Dumptube, 7cm Ported Turbine Housing w/34mm flapper mod, 3" Extreme/Thermal R&D Turbo Back Exhaust System, Hallman MBC, K&N Air Filter, Magnacore 8.5mm Spark Plug Wires, NGK BPR7ES Spark Plugs, EGR Blocked Off/Vaccum Lines Removed & Capped, K&N Breather Filter Mod, Fidanza Aluminum Flywheel, Centerforce D-F Clutch, Prothane Motor Mounts, Custom TD05H 18G Turbo...
- Mods-Engine
- Stock Bottom End
- Mods-Handling
- KYB AGX Shocks & Struts, Suspension Tech 1" Lowering Springs, Upper Strut Camber Bolts, Prothane Suspension Bushings...
- Parts Wishlist
- The part that gives your FWD off the line traction, lol!
- 1/4 Mile E/T
- 16.347
- 1/4 Mile MPH
- 91.830
- 1/8 Mile E/T
- 10.876
- 1/8 Mile MPH
- 70.630
- 60' Time
- 2.961
- Timeslip Details
- Track Name : Hawaii Raceway Park
Nitrous : no
Fuel Used : Pump gas
Vehicle Weight : 3075
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
