- Year
- 1992
- Model/Trim
- Mitsubishi Galant VR-4
- Transmission Type
- Manual
- Mods-Bolt-on
- Forced Performance exhaust manifold
taiwan EVO III GT 16G turbo
2.5" intake pipe with a mushroom top filter
2G o2 housing
3" turbo back exhaust, no cat with dynomax VT muffler
EVO 8 front mount
2.5" aluminum intercooler piping made to be as short as possible
GM IAT
OMNI 4 bar MAP sensor
IR boost controller(linked into ECMLink)
rebuilt throttle body
FIAV block off
New Biss with o-ring
all new gaskets
full heat shields
wally 255 in tank
denso 780cc injectors
full throttle FPR w/ gauge
new oem fuel filter
iridium plugs
NGK R-8 wires
91 octane with Meth Injection
- Mods-Engine
- 2g pistons/1g rods
evo 8 valves, springs & retainers
MLS head gasket
arp head studs torqued to spec
revised 3mm lifters
stock radiator
2 12" slim fans
180 degree thermostat
silicone radiator and cooling hoses
new oem water pump
fully flushed and back flushed system
- Mods-EMS & Logging
- ECMLink - V3
prosport - boost, oil pressure and wideband
- Mods-Drivetrain
- bad 1&2 gear syncros
F1 racing stage 1 clutch
ACT aluminum flywheel
apr flywheel bolts
rebuilt aluminum transfercase
rebuilt driveshaft w/ carrier bearings
redline fluids throughout
- Mods-Handling
- 4ws intact
sumitomo tires
kyb agx up front
gab adjustable rears
stock springs
prothane bushing kit
prothane motor mounts
Porterfield R4S pads up front
new rotors
front strut tower bar
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
