Please Support JNZ Tuning
Street Build Mitzie Bish
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
  2. Road Course
FP manifold
Mods-Engine
Eagle Rod/ Wiseco 86.5mm 6 bolt with oil squirt delete. (Shortblock rebuilt to hold 25psi)
Mods-EMS & Logging
Factory
Mods-Drivetrain
Enkie 2 inch drop strut assemblies
Background
Adopted this from my uncle for a $267 tow. It's just been up until recently that I've been able to work on it but has its issues. Taking inventory, I have seen that the ignition switch is bypassed with switch that i need to press at the same time I turn the key. Which is one of the main issues I need to figure out. Other than that, I have two different block builds going on at the same time. The main focus is on the 25 psi build.
Upon teardown, I found that the multi surface clutch had 7 of the 8 pads torn off the trans side of the plate and measured 1.2mm of crankwalk! Gah! She really has not been treated right.
Currently looking to build/ rebuild her as she sits to an upgraded OEM standard just shy of requiring engine management. Stories from the elders say this bish was tested at 11.6 1/4 mile so that is what I am aiming to improve upon.
Videos
JAIH
More in 2G DSM
Share this Vehicle
