1997 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
Red97Eclipseboy's Eclipse GST
Exhaust: Full Apex-i turbo-back w/Blitz Nur-Spec Muffler; F.P. race-exhaust manifold w/wrap; SBR J-pipe; Punishment O2 housing w/external dump. Intake: Blitz SUS Power intake; Injen intake pipe; MHI EvoIII16g turbo-ported w/ Tial 38mm wastegate; HKS bypass-valve recirc'd; Hahn Racecraft FMIC core; Vibrant 2.25 pipes; HTS couplers w/t-bolt clamps. Setup mounted and short-routed by me; RVR (Evo3) intake manifold w/Magnus heat-barrier gasket; OEM non-cruise cable. Fuel: Walbro 190; FIC 650's; STM fuel pump re-wire kit; STM pushlock fuel-feed line kit; Fuel Lab AFPR; Ignition: NGK BR8 plugs; NGK plug wires. Ice: Factory CD player; Alpine TypeS 6x5s front; Rockford Fosgates 6x9s rear.
Mods-Engine
Short-block: 6-bolt block w/Ross pistons (0.20 over); Eagle H beam rods; Clevite main/rod bearings; MLS head gasket and o-ringed block; ARP rod, main and head bolts/studs; OEM B.S.E.K. 2g Head: FP2 cams; Crower springs & retainers; ported head; Emissions/AC gone.
Mods-EMS & Logging
DSMlink; Greddy 52mm boost and oil pressure gauges (amber-lit); Innovate DB Red wide-band; HKS Type-0 TT (amber-lit); Greddy Profec B (amber lit) w/ remote swtich.
Mods-Drivetrain
Fidanza flywheel; ACT 2100 clutch; WaveTrac L.S.D.; Prothane motor/trans mounts; Green Glow shift-linkage bushings; hard shifter-base washers; full stainless clutch-line.
Koni Yellow shocks; GC 500/350 sleevs; front and rear strut tower braces; OEM front sway-bar; Tanabe rear sway-bar; Moog front/rear sway-bar links; Enkei RPF1 17x8 +45 wheels with 235/45/17 Dunlop Star Specs; Momo Champion steering wheel.
Brakes: OEM GSX dual-piston calipers; Brembo AWD rotors; Hawk HP+ pads; Tech-na-fit stainless lines; A.T.E. Blue brake fluid.
Corbeau Forza seats
Parts Wishlist
Racing Hart C2 Evos; Recaro seats; FP3052; Shearer FMIC
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Track Name : Great Lakes Dragway
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
AMS
Dyno Session Details
Nitrous : No Nitrous
Turbo : Evo316g
Boost : 17
2G DSM
Red97Eclipseboy
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this vehicle
