RayPeters's Talon TSi AWD
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- GT35R
Eaton M62 Gen IV Supercharger
Custom Intake manifold to support supercharger
1600 cc Injectors
Dual fuel pumps
DS-MAP Speed Desity on factory ECU
Autometer Gauges; boost, Fuel Pressure, Oil Pressure, EGT, Zeitronics wideband A/F.
Fixed pressure Fuel pressure Regulator
Custom Bell Intercooler Water/air system
1G NA Throttle Body
Custom 3" Exhaust w/ converter
Super short route piping
50 mm BOV integrated in Heat Exchanger
Lightweight 2900# Pressure Plate
Superlight Aluminum clutch disc
Fidanza Aluminum Flywheel
TRE EVO Tranny
Upgraded front axles
TG6607 oil filter (Clears header with ease)
Custom 304 stainless Exhaust Manifold
- Mods-Engine
- Fully built /blueprinted bottom end
2.4 crank
JE 8.3 Forged Pistons
Port Matched 1G Cylinder Head
272 Cams
ARP Head Studs
O-ringed head gasket
Balance shaft Removed. using long shaft in Rear
- Mods-EMS & Logging
- DS-Map
3 Bar Map sensor
IAT sensor
- Mods-Drivetrain
- Prothane Engine Mounts
Custom UHMW Polyethelene Front Sub-frame mounts Available now)
Custom UHMW Polyethelene Rear Sub-frame mounts (Available now)
- Mods-Handling
- Custom Valved KYB Struts (Rears)
KYB Gravel spec front struts
450 #/inch front springs
675 #/inch rear springs
Custom solid front control arm bushings)
- Parts Wishlist
- Ear plugs....
Clutch for supercharger
- 1/4 Mile E/T
- 10.525
- 1/4 Mile MPH
- 136.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 1.640
- Timeslip Details
- Nitrous : No
Fuel Used : E85
Vehicle Weight : 3205
Tires : DOT Slicks
Sponsored Car : no
- Dyno TQ
- 525.0 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- TDC, Mobile AL
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : E85
Turbo : GT35R
Boost : 31
