- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse Spyder GST
- Transmission Type
- Manual
- Mods-Bolt-on
- injen intake has custom stainless steel intercooler pipping and a front mount hks intercooler. also has a custom injen upper intercooler pipping with a hks blow off valve.
- Mods-Engine
- the turbo is a small 16g, only saw 15psi,ported J-Pipe, has a stainless steel header, and also a the maf was eliminated and replaced by a gm 3in mas sensor with a maf translator has a first gen intake, HEAD/ with 1mm oversized valves, 264/272 cams, hks adj cam gears, 3rd gen lifters, valve guides, mildly ported also. and COIL over PLUGS the block has 2g pistons with brand new rings, 1g rods machined for the crank,evo 8 injectors, brand new oil pump, water pump, timming belt, alternator, balance shafts eliminated, crank under pulley, and all brand new gaskets
- Mods-EMS & Logging
- pocket logger New walbro 190 lph fuel pump and fuel filter
- Mods-Handling
- act 2100 series clutch OBX camber kit for front and back,new tie rods and control arms,it has a b&m short throw shifter also.kyb gr-2s and tein lowering springs icw racing rims 17'' low profile kumos
- Parts Wishlist
- bigger turbo new interior have it tuned
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
