projekt becki
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
FWD
Automatic
Build Type
  1. Street
  2. Drag Race
Weapon-R Dragon Cold Air Intake
SR-S Catback
Galant 90 Amp Alternator
0 Gauge main ground
Mods-Engine
Poly motor mounts
Fiav/Isc Delete
EGR Delete
EVAP Delete
Cruise Control Delete
Evo 8 Fuel Pump
Fuel pump rewire w/ killswitch
3kgt VR4 Oil Filter
A/C Delete
Test pipe
1G N/A Throttle Body
450/cc Injectors
482 Maf
Mods-EMS & Logging
Openport 2.0/FTDI OBD2 Cable
Innovate LC-1 Wideband (Simulating Narrowband)
Ecuflash/Evoscan w/ Ceddy Mods
Glowshift Red Digital Oil Pressure
3G Ecu w/ Tephra Mods (9653)
Mods-Drivetrain
Alto Red Eagle Rebuild Kit
Translab STL-175-HP
Sonnax Manual Valve
Sonnax Shim Kit
Hayden Trans Cooler (don't remember the size)
Whole lot of oem bolts.
Glowshift Red Digital Trans Temp
Generic Front Strut Tower Bar
Kumho Ecsta XL Platinum
GSX Calipers (front/rear)
Drilled/slotted Rotors (front/rear)
Ceramic Pads (front/rear)
OE Rear Sway Bar (Moog End Links)
3G Master Cylinder
AWD Kyb GR/2 Struts
Tien S.Tech Springs
Parts Wishlist
DOHC Swap ( Have 2G 63 head)
E85 Swap
Wire Tuck
Background
2.4 DOHC Turbo, with a built fwd auto tranny. Maybe awd someday.
infam0usdeed
More in 2G DSM
Share this Vehicle
