- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Parts Wishlist
- 40,000+ Miles
Walbro 255 pump $108.99
HKS 272 $355.00
Thermal Research Exhaust $620.99
Megan Downpipe $178.43
Highflow Cat $365.90
Short shifter (cut welded) $58.92
Steel bushing shift kit $62.20
B16G $779.00
O2 housing with dump $299.00
DSM Link V2 set 18-19 psi $544.99
Drilled Slotted Rotors (rear) $120.76
Custom Front Mount Intercooler & piping $506.99
60mm 1G throttle Body $120.00
FIAV/IAC removed(0)
Ported Exhaust Manifold $475.00
Greddy Type S BOV $59.99
Injen intake pipe $280.70
K&N intake filter $59.99
OEM timing belt $80.32
Gauges (just look inside the car ,ha ha) $78.60
Balance shaft removed (stub,shaft w/o oil groove) $51.23
Compressor removed(0)
Emissions removed( including charcoal canister)
EGR block off plate $20.00 [So that means less dirty air being routed back to the intake via the EGR, so cleaner air/fuel mix. I recently bypassed the FIAV so that I don't need coolant routed to my throttle body. Keeping the ISC to aid cold start idling.]
Wheels RH Evolution C2 18x $760.00
Tires BFGoodrich 225/40ZR18 SCORCHER T/A $450
Front seats Tenzo R $390
60,000+miles
Mitsu multilayer head gasket (may be regular now) $116.85
ARP head studs $107.99
Spec aluminum flywheel $330.12
ACT 2600 pressure plate $289.95
Spec Stage 3 clutch (6 puck sprung) $299.99
Koyo radiator $254.97
Cam gear ( Fidanza?) $176.52
JM Fab PC680 battery $128.99
JM Fabrications Small Battery Mounting Kit $142.77
MagicDrift 2G DSM Splitter Style Front Bumper Lip $ 102.00
65,000+miles
Hawk brake pads $89.96
Stoptech slotted rotors (front) $188.95
Eibach Prokit $244.99
KYB GR-2 shocks $254.90
Prothane Motor mounts $86.97
Hallman boost controller $115.00
650cc injectors (used) $60.95
SS Brake line $115.43
ATE Super Blue Brake fluid (Rare) $74.99
70,000+
Taylor Cable 48010 Red Single Trunk Mount Battery Relocator Kit 150.89
Battery Power Junction Post Block(Red & Black Set) Stainless Steel Stud $15.99
AutoZone Duralast Gold $198.99
MagicDrift 2G DSM CS Style Side Skirts Winglet $158.88
80,086
DFJ Underdrive Pulley Kit $118.82
Continental Power Steering belt belt $22.99
Continental Alternator belt 23.99
OEM 4G63 Crankshaft Timing Gear Sprocket $48.09
Extreme PSI Timing Belt Tool Kit: 4G63T $69.00
Gates Economy Complete Timing Belt Kit with Water Pump $184.50
STM Tuned Water Pump Pulley Bolt, OEM Crank Pulley Bolt $24.67
HKS Purple Timing Belt $213.75
Aluminum Universal Water Radiator Cooler Mugen Jdm Cap Purple $18.40
Ralliart Billet T6061 Aluminum Engine Oil Cap Purple $17.45
Car Refitting M6 Pad Screws Accumulat purple $14.80
Cam Gear Timing Belt Cover Turbo RVR $23.07
Average of Total Expense 11,313.57
