1990 Eagle Talon TSi AWD Vehicle Profile & Build Thread
paradoxtar's Talon TSi AWD
Eagle Talon TSi AWD
PTE 50 trim turbo, Denso 720cc injectors, EVO o2, 2.5" to 3" ss down pipe, N1 cat back, mbc, Fidanza fly wheel, ACT 2600 and 6 puck, built TRE tranny with Quaife front and center diff, bolt on adjustable fpr, AN o8 billet filter and fuel line TANK to rail, Walbro-255 hp fuel pump, EGT/BOOST/FUEL PRESSURE/TURBO TIMER/AF RATIO gauges, upgrade sidemount intercooler with 2.5 in/out, 2.5 lower i/c pipe, 2.5 upper i/c pipe and elbow with water sprayer on the outside, FP exhaust manafold , Brian Crower stage 1 cams, Magnecor, 4 bolt rear end, energy suspension, Bear brakes with drilled and slotted rotors, Cooling Mist water, meth, and intercooler sprayers yep 3 systems, etc...
Mods-Engine
Balanced rods and pistons Wiesco/Eagle, all ARP, 1mm over valves, mild port, 4 layer metal head gasket, Extrude hone intake manifold and 63mm throttle body, balance shaft delete, crank balanced.
Mods-EMS & Logging
ECM Link V3 both cars
Mods-Drivetrain
4 bolt rear end, ACT 2600, Bilstien struts, Bear brakes front, 17" wheels
brake upgrade, 215X45X17 tires, ss brake lines
Parts Wishlist
Finish the 1931 Ford model A with 4g63 and Tremec T56 tranny
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Track Name : LACR
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3400
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
1G DSM
paradoxtar
More in 1G DSM
Share this vehicle
