- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- 20g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- tdo6 sl2 20g billet 6 blade. 1250 fic injectors. re-wired wally 255lph fuel pump, fuelab afpr and filter with 6an braided lines, comp cams 101 -201. crower springs and retainers. fidenza cam gears. 2g maf, vrsf 3.5 inch fmic. megan down pipe. 3inch straight piped, porterd 2g exhaust mani and o2. mtxl wide band, pro sport oil pressure, prosport boost gauge, hallman mbc, balance shaft delete, new oem timing components, touque solution engine mounts , comp stage 3 clutch kit, oem master and slave with briaded clutch line, oem clutch fork, pivot ball and throw out bearing.
- Mods-Engine
- complete overhauled 6 bolt bored .40 over. tourque plated, honed and decked, wiseco pistons, eagle h beam rods, 4130 eagle crank, king bearings, crower spring and retainers, comp cams 101-201. all new seals and gaskets. head decked and hot tanked. balance shaft delete. oil port mods
- Mods-EMS & Logging
- Dsmlink v2.5. mtxl wide band. prosport boost and oil psi gauge,
- Mods-Handling
- oz rally 2g edition/evo5 wheel with 255 50 16. falken azenis . megan coil overs
- Parts Wishlist
- v3 or v4! 272 cams, 2150 fic, 450 wally
- Background
- 49,000 original miles,(daily driven now)with rebuilt 6 bolt. friend had it in high school around 2006, it blew up and was stored in a barn ever since, I have now brought it back from the dead better that ever
