1992 Eagle Talon TSi AWD Vehicle Profile & Build Thread
nkosi's Talon TSi AWD
Eagle Talon TSi AWD
jdm 4G63 with PTE 6262SP 1000cc injectors , BC 272/272 Cams, Dejon 3" intake pipe, megan racing 3" down pipe, ETS Race 31x10.5x3.5 intercooler and piping, MAF-Translator Pro in Speed Density with Dsmchips tuned Ecu , K&N filter, walbro255lph fuel pump, fuel lab pressure regulator , Forced performance race exhuast manifold, punishment 38mm Rec. O2 housing , Tial 38mm external wastegate, Dejon 3" centre exhaust piping with Megan racing 3" muffler , Gizzmo MS-IBC boost controller, Palm m105 with MMcd.prc, extreme psi upgraded fuel feed line with fuel-lab 818 filter and AFPR s/s line kit, AEM high volume fuel rail, Gates racing rad hose kit, MSD DIS-2 Ignition with stage timing retard, Blitz turbo timer XTR , Hydro HP Methonol Injection kit , AEM ugo gauge type wideband sensor kit
Mods-Engine
Ross Racing 8.5.1cr pistons ,Crank Shaft Depot chromoly HD Rods and 6 bolt crank polish and balanced TKrace.com ,Stage 3 Cylinder head package from SIM racing s/s valves Manley stage 2 Valve Springs , Tkrace.com port/polish and flow tested ,ARP everything
Mods-EMS & Logging
AEM EMS in speed density tuned by Pat @ Auto Concept
Mods-Drivetrain
stage 5 ACT 3200lb 6 puck race disc and pressure plate, stainless steel clutch line,fidanza aluminum 8lb flywheel, dsm extended slave cylinder rod.
twin piston calipers cross drill rotors with carbon metallic pads, canuck motorsports 1.5 inch lowering spring with kyb gr-2 shocks and struts, s/s brake lines front and rear
Parts Wishlist
TurboTrix built Race transmission
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
468.0 lb/ft
Dyno Type
Mustang Dyno
Dyno Session Details
Fuel Used : Pump gas
Boost : 25
1G DSM
nkosi
More in 1G DSM
Share this vehicle
