- Transmission Type:
- Manual
- Mods-Bolt-on:
- Pro Sport boost gauge & water temp gauge, Hallman Pro boost controller, 1g b.o.v., Full 3" exhaust, Tein Basic coilovers, hard intake, 1g throttle body, K&N air filter, secondary direct flow water-temp sensor, 11.5 lb chromoly flywheel, Hurst short shifter, Gates timing belt, brass shifter cable bushings, nylon shifter plate bushings, ss clutch line.... Full 97 body conversion....... More to follow....
- Mods-Handling:
- Tein Basics, poly bushings
- Parts Wishlist:
- Fp Green or MHI 20G turbo, dsm-linkv3 'full', 550cc injectors, nice fmic, 1-piece aluminum drive shaft, .......272 cams & springs set......Professional tune and leave it alone.....
Join the Community!
Comments
Sort Comments By
