- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Mods-Bolt-on
- Poly Tranny & Drivers Side Mounts,
Front & Rear Poly Roll Stops (Black GST's),
1000cc FIC Injectors,
Aeromotive AFPR,
Walbro 255,
SS Oil Feed Line,
Mishimoto Radiator w/ 2 12' Slim Fans,
Holset HX-35 7 Blade Turbo,
VRSF FMIC,
Greddy Type RS BOV,
Fuel Labs Fuel Filter & SS Line To Rail,
Full race ram horn manifold
Brothers External Wastegate 38mm,
3 Inch Exhaust,
Pr True 3 Inch Downpipe,
STM Fuel Pump Re-wire Kit,
Custom Coolant Overflow Tank (92awdgsx's),
Greddy Catch Can,
Fp 4 Inch Intake
- Mods-Engine
- Stock 97 7 Bolt
3g Revised Lifters
ACL Rod Bearings
Arp head studs
- Mods-EMS & Logging
- Aem Uego,
Aem Boost,
Aem Oil Pressure,
Ecm Link V3 Full,
Ecm Link Speed Density Kit w/ plug and play maf cable
- Mods-Drivetrain
- SS Clutch Line From Master To Slave,
STM Shifter Base Bushings,
Comp Billet Clutch Fork,
B&M Short Shifter,
Clutch masters stage 3
Greddy Shift Knob,
Torque Solutions Rear Subframe & Carrier Bearing Bushings,
RRE Rear End Poly Bushings
- Mods-Handling
- 17" ICW,
Nitto Invo 235/45ZR17,
Awd Calipers Front & Rear,
Drilled & Slotted Rotors Front & Rear,
SS Brake Lines Front & Rear
- Parts Wishlist
- Finish My 6bolt 2.3L Stroker
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
