Mitsubishi Eclipse GSR-4 Extreme
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- MMC JDM & Euro Conversion (pop-up lights, side markers, light angle dial, rear/front lighting fascia, KPH instrument cluster, etc.)
MHI TD05 20g bastard (16g hotside)
GVR-4 RS Cyclone Intake Manifold + Jegs RPM Switch
Ported Evo III Exhaust Manifold
Gates Timing Belt and matching components
3" Custom Exhaust with "Good neighbor" and "Bad neighbor" mode
TIAL 50mm BOV
Electronic Boost Controller 15/25psi (A/T PWR/ECO button toggle)
Rewired Walbro 255lph
Aeromotive AFPR
1600cc Bosch Fuel Injectors
AN Lines/Fittings for Fuel and Oil
EIII USA FMIC w/ Dual Slim Fans
Gold Wrapped Hard IC Piping
13 Row Oil Cooler
OEM Ralliart Lug Nuts
Snow Performance Stage 2 Progressive Kit
- Mods-Engine
- 4G64 100mm Eagle Crank
Wiseco 2.3L Stroker Pistons (8.7:1 CR)
Manley H-Beam Rods 150mm
Kiggly Main Girdle
ATI Super Harmonic Damper
Kiggly Racing 4G63 HLA Pressure Regulator
Evo VIII Oil Jets
ARP Head Studs/Rod Bolts/Main Bolts
ACL Race Main and Rod Bearings
Brian Crower 272/272 Cams
Brian Crower Springs/Titanium Retainers
Brian Crower Oversized Intake and Exhaust Valves
Manganese Valve Guides
Supertech Valve Stem Seals
Oil Gallery Port Mod
3G Lifters
Fresh motor mounts
- Mods-EMS & Logging
- ECMLink v3
Speed Density Omni 4-Bar
Innovate Wideband Unit
HKS Turbo Timer
Defi Boost/EGT/Oil PSI gauges
- Mods-Drivetrain
- 4-Bolt LSD Rear Differential
Freshly Rebuilt Transmission, Transfer Case & Rear Diff
PowerTrain Technology (PTT) 7.25" Twin-Disc Clutch
Billet Clutch Fork
OEM Sleeve Yoke Recall Repair Kit
OEM Clutch Master Cylinder w/ 2g long rod swap
Isuzu Trooper Clutch Slave Cylinder
Braided Full SS Clutch Line
Fresh OEM spider joints
Fresh OEM carrier bearings
Fresh OEM lobro joint boot
Energy Suspension prothane bushings
WSS Billet Shifter Bushing Bracket
- Mods-Handling
- Modified Stealth Coilovers
Adjustable Rear Camber Arms
225/45/17 2020 Accord Fanblade Wheels
50mm Front Spacers
50mm Rear Spacers
3000GT VR4 Front Brakes
330mm EBC Cobra dimpled/slotted front rotors
EBC dimpled/slotted rear rotors
Braided stainless brake lines
3g master brake cylinder
Fresh Timken wheel bearings and studs
- Parts Wishlist
- GOT IT RUNNING MAY 11th, 2024
Rebuild spare transmission with my Magnus Billet Shift Forks 1-2/3-4
- Background
- Bought in 2010 and has been a garage potato/demanding diva ever since.
Plastidipped "Anthracite" & "Stealth Black"
Rebuilt in:
2012 Cause: Crankwalk
2014 Cause: Exploding clutch
2021 Cause: Cracked piston
2023-2024 - Extreme Final Restoration Build
