- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Mitsubishi Galant VR-4
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Borg Warner S257XE 7670 with T3 AGP .82 A/R single scroll turbine housing, Tial 44mm recirculated, custom 3" downpipe, Front mount intercooler, 3 inches exhaust, MAP Performance tubular exhaust manifold, Turbosmart BOV, magnaflow fuel regulator, magnecor wires, 1000cc ID injectors, walbro fuel pump.
- Mods-Engine
- Full ported cylinder head, Supertech SS valves stock size, Supertech double springs and bronze valve guides, Kelford 272-272, custom composite head gasket 1.9mm with o-rings, Kiggly racing main girdle and HLA, ACL main and rod bearings, AEM tru-time cam gears, Wiseco 86.5mm HD2 8.5:1 pistons, Manley TT Long rods, MAP H11 head studs, ARP main studs, ARP flywheel bolts, Fluidampr pulley, custom oil pan buffle, oil relief valve mod, head oil mod
- Mods-EMS & Logging
- AEM EMS 2, AEM TRUBOOST, AEM WIDEBAND, AEM IAT, AEM MAP sensor, AEM EGT sensor, AEM sensors for fuel pressure - oil pressure at filter housing and oil pressure before turbo, Shiftlight.
- Mods-Drivetrain
- Clutch masters high rev pressure plate with 6 puck disc , fidanza flywheel, Quaife LSD
- Mods-Handling
- Koni coil over adjustable
