- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- ;Evo lll 16g
;C.X. RACING FMIC 22"x10"x3"
;Full 3" custom exhaust
;2.5" custom s.s o2 housing
;K&N filter
;1G 60mm T.BODY
;1g bov
;Full prothane engine mount kit
;C.X. RACING radiator
;Hallman pro cockpit boost controller
;Custom MAF pipe
- Mods-Engine
- ;6 bolt block
;2g Cylinder head
;B.S. Delete "OEM"
- Mods-EMS & Logging
- ;AUTOMETER sportcomp boost gauge
;AEM uego wideband o2
;Glowshift volt gauge
;Glowshift oil pressure gauge
;Fuel Pump Rewire "30a"
;WALBRO 190 F.P.
- Mods-Drivetrain
- ;Fidanza flywheel
;ACT 2200lb
;Full Prothane Bushing kit
;Solid shifter base and end bushings
;Short shifter kit
;11lb Chromoly flywheel
;Stage lll 2900lb ECM pressure plate w OEM disk
- Mods-Handling
- ;D.S Rear brake rotors
;Custom rear strut tower bar
;Tokico illumina struts/ springs??
;Hot wheels 17x8 with 235 50 17 michelin tires
;1 3/8 bolt on hub extender/ spacer
;3g Rear tubular upper & lower control arms
;3g Rear sway bar & end links
- 1/4 Mile E/T
- 13.292
- 1/4 Mile MPH
- 100.720
- 1/8 Mile E/T
- 8.417
- 1/8 Mile MPH
- 80.690
- 60' Time
- 1.729
- Timeslip Details
- Track Name : P.M.I.
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3050
Tires : Street Radials
Altitude : 5600
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
