- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Engine
- Gates Racing belt
Npr Replacement Pistons
Stock Reconditioned Rods
New ITM oil pump
Completely Machined Block Bored .030 over
CBN resurfaced head and block
Complete rebuilt Head with Stage 2 porting and 3 angle valve job and new Viton valve stem seals.
New OEM Freeze Plugs
New Npr Piston Rings
New ARP Rod Bolts
New ARP Head studs
New OEM Main Bolts
Rods Aline Honed and Reconditioned
Balance shaft eliminator kit
- Mods-EMS & Logging
- Air fuel Ratio gauge
Boost gauge
JDM fuel pressure regulator and boost controller
- Mods-Drivetrain
- New machined CV shafts
New transmission and transfer case seals
Aluminum Shifter Bushing Kit
Short throw shifter
Stainless Steel clutch hose
New Hub seals and bearings on front
- Mods-Handling
- New cross drilled slotted rotors and pads
new lower A arms
New sway bar links
New tie rod ends
- Parts Wishlist
- Bigger Turbocharger
Complete 3" Exhaust system
Bigger Spoiler
ECM Link V3 lite
ABS deletion Kit
Battery Relocation Kit
Carbon Fiber Hood
Alcohol Injection Kit
Lambo Door Kit
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
