Street Build Just a quick street car build
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
Apexi n1 Exhaust
MAP intercooler (comparable to VRSF)
Custom 4 inch intake
Turbonetics T3 manifold
Morrison fab hy35 downpipe
Hy35 rebuilt from Justin (@28 psi, currently on pump gas)
FIC 1120 injectors
DW 200 fuel pump
Fuel lab regulator
Speed density
Tial mvs wastegate
Tial Q bov
Mac 3 port boost solenoid
Mishimoto radiator with giant spal fan(1777 cfm) and small spal ac fan
Recently rebuilt throttle body from tim over at that performance
Agm battery
Zacklee timing belt cover
Frontline fabrication dipstick handle
Mods-Engine
7 bolt motor Block:
Wiseco pistons (8.5 comp)
Eagle Rods
Stock crank
.20 over
Composite Mitsubishi Headgasket with ARP studs
Fluidampr crank pulley
Head:
7 bolt head
Brian Crower 272 cams
BC springs and retainers
SS valves
Kiggly hla
Mods-EMS & Logging
DSMlink V3
Aem x series wideband, Autometer boost and oil pressure gauge
Just a tune, tuned
Mods-Drivetrain
Shep build stage 3 transmission with 4 Spider Diff
Southbend SS b series full ceramic disc
Xtd flywheel
Oem TB
Comp Clutch Fork
Stock transfer case
Stock Differential
B&M short shifter
White shed speed shifter cable bracket bushing
Solid shifter base bushing/shifter cable at trans bushing
Tokico Shocks with springs (1 inch drop)
Montero bigger brake kit ww ss brake lines
Hawk 5.0 brake pads
Asa ar1 wheels currently on winter tires
1/8 Mile E/T
7.96
1/8 Mile MPH
91.1
Timeslip Video Link
Watch Video
Dyno HP
404 whp
327 lb/ft
Dyno Type
Mustang Dyno
mitsumike0
More in 2G DSM
Share this Vehicle
