JamesonTSI-AWD's Talon TSi AWD
- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- -Straight Line Specialties 3" Turbo Back/ catless Exhaust
-Custom black center heater vent Bezel w/ Glowshift Boost and A/f Guages
-Holset HX-35 Turbo w/ inch Inlet
-SS Autocrome FMIC
-Walbro 255HP
-Fuel Pressure Regulator
-FIC 850cc Injectors
-DNP-32 Manifold w/ TIAL 38 mm Wastegate
-Forced Performance 4 inch Intake w/ K&N 9" cone Filter
-HTS 4 Ply 90 Degree Elbow : 2.50"
-Stainless Steel T Bolt Clamp : Fits 2.50" I.D. Coupler
- Mods-Engine
- -6 bolt swap
-Wideband and controller
-FFWD DKS3 280 cams
-Brian Crower Springs and Retainers
-Ferra Intake Valve seals-ARP Head Studs
-Balance Shaft Elimination
-Mitsu 4 Layer HG
-Throttle Body to Throttle Body Elbow Gasket
-Cam Angle Sensor O-Ring
-Front Main(crankshaft) Seal
-Blow Off Valve Gasket
-Camshaft Oil Seal
-Oil Pump Shaft Seal
-Thermostat Housing Gasket
-Water Pump O-Ring
-Water Pump Gasket
-Thermostat Gasket
-Rear Main Seal
-Rear Main Gasket
-ACL Race "Tri-Metal" Rod Bearing Set
-ACL Race "Tri-Metal" Main Bearing Set (+.001" Oil Clearnace)
-Scat Pro 4340 Forged H-Beam Connecting Rods
-Wiseco Forged Pistons w/ Rings 8.3:1
-Ferrea Exhaust Valve Seals
-Valve Cover Gasket Set
- Mods-EMS & Logging
- Megasquirt 2
- Mods-Drivetrain
- ACT2600 lb. Clutch, and streetlight Flywheel
- Mods-Handling
- Teinn SS Coilovers
- Parts Wishlist
- Magnus Intake Manifold
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : Pump gas
Tires : Street Radials
- Dyno TQ
- 0.0 lb/ft
