1995 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
Street Build
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E25 w 1000cc inj. ~23psi. Street driven track day car.
ITFLYS - 1Gina2G
Ownership Status
Currently Own
Turbo Type
20g
Drivetrain
AWD
Build Type
  1. Street
KN Intake Cone, Custom RRE Big side mount IC, RRE IC piping, Greddy Type-S BOV, Modified 3" APEXi WS exhaust, B&M Shifter, Painted carbon fiber hood, SPARCO R100 seats and sliders on WEDGE brackets, Scroth 4pt harness
Mods-Engine
JDM 6 Bolt w 1G-rods and 95 pistons, B-Shaft delete, 1G-TB, Port match 1G-Intake, AEM-340lph Fuel Pump w 1/8” siphon return mod, Radium Fuel rail and DMRegulator, 1000cc RC injectors, Port polished 1G-Head, Stock 1G Cams, Ported E3 Exhaust Manifold, TD05H 7cm Bastard 20G Turbo w extended tip billet compressor wheel and 15deg clip turbine wheel, E3-O2 housing, SETRAB Air-Oil cooler
Mods-EMS & Logging
ECM Link v3 with Kiggly Crank sensor, 2Gb Cam sensor, ZT-3 Wideband, GMIAT, ZT-50psi MAP sensor, Speed Density. PiLink onboard ECM Link logging computer and stereo head unit replacement with 7" Touch Screen, Android Auto, Apple Car Play, RearView cam, Cloud synced logs, Retro Arcade games and CAN bus. STACK Dash instrumentation with CAN bus triggered lap timer. Custom DashControl app, Custom bright LED panel mount indicators, Race Capture Track MK2, Race Capture triggered GoPro HERO4 action camera.
Mods-Drivetrain
X-Clutch - Lightened Flywheel
Muellerized OHLINS coil over suspension and modified front upper A-arms, Dudes POM Sub frame bushings, suspension bushings, drive line bushings, Volks rear toe arms, RM rear swaybar, StopTech front brakes, 17x8" Wheels
Parts Wishlist
more ethanol
Background
Track day addict, restoring my ride after a long pause of activity.
Timeslip Details
Big16G data - 20G is untested.
Dyno HP
382 whp
354 lb/ft
Dyno Sheet Photo Link
Dyno Shop Name
ECMLink calculated from logs using accurate weight
Dyno Session Details
https://www.dsmtuners.com/threads/itflys-1gina2g.532766/page-32#post-153903404
Videos
Table of contents
2G DSM
Justin DuBois
Watchers
5
Comments
More in 2G DSM
Share this vehicle
