- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- -3in. Thermal Research Exhaust
-2G ported exhust manifold and O2 Housing
-EVOIII 16G
-FIC 850 injectors
-ACT flywheel and act 2600 clutch
-Greddy type S bov
-Spearco 2-216 FMIC
-Full 2.5 inch intercooler piping
-Injen intake pipe
-K&N air filter
-Greddy Kevlar timing belt
-Polyurathane front and rear motor mount inserts
-Aluminum underdrive crank pulley
-Aeromotive Fuel pressure regulator and guage
-Walbro 255lph Fuel pump
-B&M Short throw shifter
-Clear marker lights
-Autometer Boost guage
-Greddy EGT guage
-Greddy manual boost controller
-Stainless brake lines
-Stainless fuel line from filter to rail and rail to regulator
-Modded front bumper without talon symbol
-Tinted windows 50%F/20%R
- Mods-Engine
- -6 Bolt Motor (JE pistons 9.1 .020 over, eagle rods, balance shaft eliminator kit, clevite bearings, arp head studs, new pulleys, oil pump, and front case.
-1G ported and polished head, stainless valves, 5 angle valve job, SI dual valve springs and titanium retainers, and new valve seals.
-Forced Performance FP2 Cams.
- Mods-EMS & Logging
- -Eprom ECU with DSMLink V3
- Mods-Drivetrain
- Stock
- Mods-Handling
- -Tokico illumina shocks and springs
-18" Axis rims and tires
-Slotted/drilled brake rotors
-Rear strut bar
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
