1. Join the Community!
Street Build GVR4 866/1000
Year:
1992
Model/Trim:
Mitsubishi Galant VR-4
  • Ownership Status:
    I own it
    Turbo Type:
    20g
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    5-lug conversion
    EVO VIII Brembo front calipers
    ABS Delete
    Mods-Engine:
    Eagle Rods Ross Pistons (8.3:1 comp, .020 over)
    ARP L19 Head Studs
    Mildly ported head
    Kiggly HLA 3g lifters
    Knife-edged crank
    Balance Shafts Eliminated
    BC 272 Cams
    AEM Adjustable Cam Gears
    Poly timing side mount Factory front/rear mounts
    PTE 1200cc Injectors
    FP Exhaust Manifold
    Tial Q 50mm BOV
    FFOFH
    68HTA killer by Chris Robbins (20g Billet comp/9-blade turbine, TD06 turbine housing, 18mm collar upgrade and dual port oil feed thrust plate upgrade.)
    Mods-EMS & Logging:
    DSMLink v3
    Innovative LC-2 WB
    AEM Digital Oil Pressure gauge
    ProSport EVO digital Boost and Water temp gauges
    Mods-Drivetrain:
    Stock GVR4 5-speed trans/xfer case
    4-bolt LSD swap
    RWS deleted
    Symborski shifter bushings
    Brass shift cable bearings
    OEM TOB
    Competition Clutch chrome-moly clutch fork
    Competition Clutch Stage 3 Segmented Ceramic clutch set
    New OEM Flywheel
    Mods-Handling:
    GC Coilovers on KYB AGX’s
    5-lug conversion
    ABS Delete
    Background:
    Saw the shell for sale and it happened to be local. I bought it and transferred everything from 1025/2000 over to it
Share this Item
Ludachris likes this.
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
