- Year
- 1991
- Model/Trim
- Mitsubishi Galant VR-4
- Mods-Bolt-on
- Forced performance turbo manifold
Magnus SMIM
stock 1g throttle body
Slowboy racing G60 turbo
Punishment Racing o2 housing
PTE 38mm external waste gate
Megan Racing 2.5-3" down pipe
ETS 10" short route intercooler kit
Tial 50mm Q BOV
Forced performance air intake
- Mods-Engine
- Comp101200 cams
ARP Head studs
Cometic 1.3mm metal head gasket
Manley valve springs
Manley titanium retainers
Manley locks
Stock valves
Fidanza Cam Gears*have not yet arrived*
Gates timing belt kit
Stock 6bolt pistons*New Hasting rings*
Stock 6bolt rods
Balanced stock 6bolt crank
ACL rod bearings
ACL main bearings
ARP rod studs
ARP main studs
Front and rear balance shaft delete
- Mods-EMS & Logging
- ECM link V3
GM IAT
Omni Power 4bar MAP
ECM link plug and play SD harness
PLX air/fuel gauge
AEM tru boost controller
AEM oil pressure gauge
HKS Type 0 turbo timer
- Mods-Drivetrain
- Prothane motor mount kit
ACT 2600 clutch kit*street disc*
ACT Flywheel
Slave cylinder extension rod
4bolt rear end
steel braided clutch slave cylinder line
Stock transmission
Welded center diff
- Mods-Handling
- Ksport coilovers
Megan racing upper strut tower bars front and rear
17" Rota Subzeros
Kumho ecsta 215/45R17
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
