- Ownership Status
- Currently Own
- Vehicle
- 1995 Mitsubishi Mirage
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Custom intercooler and 2.25in piping
70mm Throttle body
Cusco Racing Solid Engine Mounts
- Mods-Engine
- 2.0l 6 bolt 4g63 block/7 bolt head
EVO oil squirters
Manley H-beam connecting rods
Manley 8.5:1 Pistons 85.5mm
Eagle crankshaft
11k RPM balanced
ARP Main Studs
ACL Race Bearings
ARP Head Studs
3mm revised lifters
Brian Crower 272/272 Cams
Brian Crower Valve Springs and Retainers
HX-35 turbo
(temp) EMUSA WG with TiAl Big Blue and Small yellow springs
KOYO Aluminum Radiator
1300cc DW injectors
CX racing FPR
Custom 3in turbo-back exhaust
10Gal Fuel Cell
Bosch 040 Fuel pump
6an feed and return lines
- Mods-EMS & Logging
- EVO 8 ECU Tephramod V7/Phenem SD E85/93Oct
OMNI 4 bar map
GM MAT sensor in manifold
GM 3 port boost solenoid
- Mods-Drivetrain
- GVR4 W5M33 Transaxle
Lancer GSR Rear Subframe, Differential, Axles and Driveshaft
ClutchMaster Clutch Fork
EXEDY twin disc clutch and lightweight aluminum flywheel
- Mods-Handling
- BC Racing Coilovers 10k all around
17X9 et25 Rota Grids
245/45r17 BFGoodrich Sport COMP-2
GVR4 Front knuckles, 2 piston calipers, and slotted rotors
Whiteline Anti-Lift kit
EVO 3 JDM Sway bars and strut tower bars
Skunk 2 Aluminum Control Arms
HKS adjustable rear toe/camber arms
- Parts Wishlist
- Full Cage, Race Seats, Etc.
