francis_710's Eclipse N/T (w/turbo)
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse N/T
- Transmission Type
- Manual
- Mods-Bolt-on
- RS*R cat back exhaust system
- Mods-Engine
- AEM tru-time cam gear
- 5 bolt, black anodized outer with red anodized center.
AFX Underdrive pulley
-Machined from a solid piece of Aircraft Grade 6061-T651Aluminum Machined on the same equipment that has made parts to fix the Hubble Space Telescope and makes other parts for NASA Space Missions. This enables us to provide very high quality. The pulley provides a 30% under drive, but still operates fine under normal driving conditions. This reduces the power lost to the accessories. Light weight, the AF/X Pulley weighs less than 2 pounds. We figured if you ever need to remove the AF/X Pulley for any reason, that would wouldn't want to have to rent that special tool again, so we engineered in the ability to use a standard harmonic balance puller to remove the AF/X Pulley.
- Mods-EMS & Logging
- Greddy E-manage Ultimate Control Unit for your Eclipse 2G
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch.
- Mods-Drivetrain
- Clutchmaster FX100 (Stage I)
· High performance street system
· Holding capacity 70% over stock
· Heavy-Duty reinforced pressure plate
· Hi-Leverage™ pressure ring design
· Sprung hub/cushioned disc
· Steel backed organic friction material
- Mods-Handling
- koni (Red) Front suspension
KYB AGX Rear suspension
Enkei 18" p255/40/z18
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Nitrous : No
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
- Dyno Session Details
- Turbo : T28
