- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Drivetrain
- FWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
255 fuel pump
adjustable cam gears
3inch thermal research exhaust
fluidyne aluminum radiator
oil cooler
- Mods-Engine
1g block
2g head
1g intake
mahle forged pistons
unknown forged rods
arp head studs
1g cas
bs delete
660 injectors
20g turbo
65 mm throttle body
turbo xs blow off valve
- Mods-EMS & Logging
boost gauge
black box ecu
voltage gauge
- Mods-Drivetrain
- 2800 stall converter
- Mods-Handling
stock suspension poly bushings
adjustable sway bar links
unknown bigger sway bar (poly bushings)
tokico shocks all around
unkown springs
continental tires
- Parts Wishlist
fuelab fuel filter and regulator
272/272 cams
wideband
dsmlink
- Background
first dsm ive ever owned. picked up this 97 up she'd been 6 bolt swapped, forged bottom end, 20g turbo and supporting mods, bunch of other goodies. all for $2000 cuz it didnt run. just turned over. it needed a fuel pump and someone didnt know which plug went to the ignition coil... lmao
plans are to build a weekend warrior that hopefully wont break everytime i drive it.
400-450hp fwd monster??
awd swap would be in the works way later since the shells so clean 70k no rust
