1990 Plymouth Laser RS Turbo Vehicle Profile & Build Thread
finnie3d's Laser RS Turbo
RRE Stainless Oil Feed Line, OE Fuel Pump Rewire, Turbo XS MBC.
Mods-Engine
3-angle Valve Job; 2G Pistons & Manifold; Balance Shafts Removed; ARP Head Studs; Solid Motor/Transmission Mounts; NGK Plugs & Wires; K&N Intake Filter;
ALL 1G "STAGE 0" POWER MODS - minus throttle body bend smoothing, and BCS restrictor.
Mods-Drivetrain
Shep Stage 2 FWD Trans w/Wavetrac LSD, DSS Stage 2 Axles, Shift Lever & Shifter Base Bushings; SS Clutch Line; Fidanza 8lb Aluminum Flywheel, ACT 2100Lb. Clutch Kit, Forged Clutch Fork
RRE Rear Strut Bar and Front Lower Tie Bar, Polished Aluminum Front Strut Bar, 2-Piston Front Caliper Upgrade, Brembo Slotted Rotors (F), Porterfield Carbon Kevlar Pads (F), RRE Stainless Brake Lines (8-Line kit), Kumho ASX Tires.
Parts Wishlist
Aluminum Radiator, ST Rear Sway Bar, Racing Coilovers, Zeitronix ZT-2 (Boost/Vac, Wideband, EGT, IAT), Turbo-Back Exhaust, EPROM ECU w DSM LinkV3 Full, Stevetek Fuel System (or FFWD Connection), Snell2010 Full Face Helmet
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
185.0 lb/ft
Dyno Type
Dyno Dynamics
Dyno Sheet Photo Link
Dyno Shop Name
Dynotuned Performance, Inc. - Chesapeake, VA
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : 14b
Boost : 11
finnie3d
Share this Vehicle
