eclipsek17's Eclipse GST (AWD swap)
- Ownership Status
- No Longer Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Autocross
- Mods-Bolt-on
- Cooling : Mishimoto radiator, slim fans mounted on front, Samco hoses
Turbo : Evo 3 16g ported, HKS SSQV bov, fmic, 2.5" intercooler piping, atmosphere dump wastegate, Hallman pro boost controller
Fuel : Walboro 255lph fuel pump, FIC 550cc injectors
Ignition : MSD spark plug wires, NGK spark plugs, Evo 3 coil packs
Intake : Evo 3 intake manifold, evo 3 throttle body, 3.5" MAFT
Exhaust : OEM manifold, straight pipe off turbo
Brakes : XRC front and rear calipers, cross drilled and slotted rotors
- Mods-Engine
- Removed balance shafts, replaced intake cam with 97 GST intake cam, 3g revised lifters, ACL tri-metal main and rod bearings
- Mods-EMS & Logging
- 99 GSX black case ecu, 97 GST CAS, oil pressure gauge, boost/vacuum gauge
- Mods-Drivetrain
- AWD swap, Stage 4 exedy clutch and pressure plate, OEM flywheel, SS clutch line from master to slave,
- Mods-Handling
- Megan racing coilovers, polyurathane bushings, rear anti-chamber kit, RRE sway bars front and rear, DC sports strut braces front and rear
