eclipse982nrrst's Eclipse N/T (w/turbo)
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse N/T
- Transmission Type
- Manual
- Mods-Bolt-on
- Venom intake manifold, Mustang 75mm throttle body, all 3 inch intercooler piping, Huge spearco FMIC, Precision SC61 turbo, Synapse 40mm wastegate, Synapse BOV, Unorthodox racing Underdrive pulley, Energy urethane motor mounts.
- Mods-Engine
- Custom 420a 2.2L stroker motor. Block bored .40 over, JE 8.8:1 pistons, Total seal rings, Custom Eagle stroker rods, Celvitte main/rof bearings, custom made Callies Crankshaft. Race ported/polished cyl. head, Stainless PEP valves, Crower 2 n/a cams, Crower valve springs, Crower titanium retainers, Unorthodox Cam gears, Tsudo n1 style 3" catback exhaust, complete 3 inch downpipe off turbo to catback, no converter.
- Mods-EMS & Logging
- Megasquirt and Spark standalone ECU, factory ECU/wiring completely removed, MSD DIS2 Plus ignition, Aermotive 1:1 FPR, Venom fuel rail, Siemens 720cc fuel injectors. Gauges: Autometer Phantom Boost, EGT, Fuel pressure, Oil Pressure, Water temp, and Volts gauge. AEM Wideband gauge/controller, MSD knock box.
- Mods-Drivetrain
- 02' Neon 3.55 trans swap, SPEC stage 3 clutch, shitty Phantom Grip LSD.
- Mods-Handling
- K Sport Pro coilovers, Rear disc conversion, front and rear cross drilled/slotted rotors, Energy suspension urethane kit, Motegi DP8 17" tires up front with Nitto NT-01 235/45/17 tires, 18'' Motegi DP8 rims in rear with Nitto 555 245/35/18 tires.
- Parts Wishlist
- Also, custom widebody kit, two tone paint job with HOK Kandy Tangerine body and HOK black pearl up top. Vis GSPEED hood.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : Pump gas
Tires : DOT Slicks
- Dyno TQ
- 0.0 lb/ft
