DSM98GSX's Eclipse GSX
- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT35 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Autocross
- Showcar
- Mods-Bolt-on
- New Setup:
JMF Drag Intake Manifold with CNC'd runners port matched to head,
Possibly WilsonThrottle Body,
Walbro 255 Pump feeding Aeromotive A1000 with surge tank,
FIC 2250cc Injectors,
Aeromotive AFPR,
Magnus Fuel Rail,
PSI Built top mount exhaust manifold,
38mm Tial wastegate,
PTE Billet GT35R,
3 inch SS DP with Full 3.5 inch Aluminum Exhaust,
DV/DT full intercooler,
Tial 50mm BOV,
B&M Oil Cooler,
Custom Louvered Hood.
- Mods-Engine
- New Setup:
2G Head:
-1mm Over Valves
-Full CNC'd port
-Polished
-Beehive Valve Springs, Seats, and Ti retainers,
-Forced Performance FP2x Cams
-Kiggly HLA Oil Pressure Regulator
6 Bolt 2.0L Long-Rod Block
-Blueprinted
-Stock Crank
-Manley Rods
-Arias Forged Pistons
-ACL Performance bearings
-Stock Oil Pump w/Stub Shaft
-Modified Oil Pick Up Tube (Kiggly Inspired)
-ARP Everything
- Mods-EMS & Logging
- New Setup:
Haltech Platinum EMS
Dynatex ARC-2
Defi D-link BF- Boost/Oil Pressure/Fuel Pressure
Stewart Warner 2 inch Tach
AEM Wideband
AEM Boost Controller
Full Custom Wire Tuck and Fuse Box Relocation
- Mods-Drivetrain
- New Setup:
PSI Built Stage IV Transmission (Open Front and Welded Center Diff)
Competition Clutch Triple Disk
DSS Aluminum Driveshaft
Torque Solutions Drive Shaft Support Bushings
Solid Aluminum Rear Subframe Bushings
Solid Aluminum Rear Diff Bushing w/4th Mount
LSD Rear Diff
DSS 900HP Rear Axles
- Mods-Handling
- New Setup:
Prothane Full Polyurethane Bushing Kit
Prothane Full Engine/Trans Mount
PSI Powder Coated Granny Smith Green Apple Drag Rims
Eibach Pro Kit Drop Springs and Tokico Struts
- Parts Wishlist
- Sparco Seats
6 Point Harness Bar
5 Pt Belts
Volk TE37 18X9
- Background
- Originally bought this car before knowing much of anything regarding DSM's or AWD. Wanted to keep the car a reasonable daily driver....ya right!
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 00.000
- 60' Time
- 0.000
